I am doing a design check to an existing portal frame. The sizes along the column height differ. The columns are compound of two UK historical sections connected with a full height plate welded on their flanges both sides.
A few questions:
1. Does Robot's database contain all UK historical sections (as in the Historical Structural Steelwork Handbook)?
2. What is the best way to model the sections?
3. Is there a difference between creating a compound section and creating the section from scratch?
thanks
Solved by Artur.Kosakowski. Go to Solution.
Hi @Anonymous
No, it doesn't.
I'd use the Section Builder module or edit one of the existing databases (depending on the exact section shapes).
Unless you want to design them as multi leg columns connected with battens or diagonals (available for selected steel codes) there isn't.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
