place beam
place beam
luismrf
place beam
luismrf
hello i need to place a beam in this location is there a easy way to do it?
i cant do it because i can´t get the intersection point between the grid and the tranversal beam.
Simau
Hi @luismrf
Tools > snap settings> select only structural axes
Select beams  467 487 502
Edit > Cut by plane
M. Agayr
luismrf
thank you @Simau ,
could you help me in this cantiliver slab i get very high value of reinforcement in these point this means that i have to put this amount of reinforcement or i can put a lower value?
Simau
Hi @luismrf
M. Agayr
luismrf
Hello @Simau ,
thank you i tryed to do you recommended but i got a error warning:
If the slab is laje 15_diryy why the main reinforcemewnt i get is in the xx direction?
Simau
@luismrf
You have changed slab thickness to orthotropic " Laje 15.1 diryy" , leave them as before as Laje escadas.
Reinforement type is set as Lajes_V2, in which main reinforcement (Ax) is // to Y global axis
M. Agayr
