Pinned-Pinned realese
Michele100100
Michele100100
Hello all,
It is correct assume In the pinned-pinned realese Rx blocked at both ends?
So bar cannot rotate on X-axes and avoid instability?
Rafacascudo
No , the default pinned-pinned release blocks rx only in one of the bar ends
Rafael Medeiros
Michele100100
thanks for your fast reply.
But If I leave as default, this is what happened to my calculation:
Instability at n.38 node and error 3060. On the lower falange of the beams where node 38 is located, I have a metal deck with concrete slab on top, Could I assume blocked rotation Rx at both ends?
Thanks if you could help.
Rafacascudo
Could you please send your model?
Zip it before attaching.
But of course , you can test it without rx releases on both sides and see if the structure still behaves properly
Rafael Medeiros
Michele100100
attached the model
Michele100100
the problem is the Moment on the columns, when is blocked at both ends the rotation RX...
see:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/moment-diagram/td-p/11375880
