Panel with opening: after mesh regerneration, the nodes are in the opening
wangjue1990
wangjue1990
picture1picture1picture2picture2Hello!
I have a question related to panel meshing regeneration.
As first picture indicated, I have a panel with opening working normally
and then I am changing the mesh settings from 1m to 0.5m meshing and regenerate mesh.
and then it becomes the situation in second picture.
question is how do I prevent the regeneration of the mesh to create node in the openings?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @wangjue1990
Make sure the openings are exactly in the panel plane. As an alternative delete the surface elements from the openings and freeze the mesh.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
wangjue1990
Thanks for the quick reply!
just few doubts:
make sure they are in the same plane:
if they are not in the same plane, how come in picture1 they generate mesh correctly?
as the other option, so you mean I manually delete the nodes in the openings and freeze that mesh?
Appreciate your answers!
B R
Jue
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @wangjue1990
If they are on the verge of the model generation tolerance it can end up in either of the outcomes.
Correct.
Artur Kosakowski
siliaaPWY4A
Good afternoon,
I 've got the same issue plus i have nodes creating mesh on the roof around the columns(see image attached). i tried to delete them but it seems that they cannot be deleted. i also remeshed my model but still the problem is there. i have attached a link with the model for your consideration. Would you recommend anything which could solve my problem?
https://design2e.egnyte.com/dl/VRNiZplzxV
thanks in advance
redundant meshredundant mesh
An alternative tip I found useful: If you select the opening or the relevant panel object and attempt to change the geometry (even if there is no resultant change), then remesh, the problem seems to fix itself. Easier than deleting and redefining.
