1. Am I reading this graphic correctly, Mxx is the moment about the YY axis and Myy is the moment about the XX axis?
2. Under the complex tab there are options for Top/Bottom Reinf and Tensile/Compressive Reinf. the check box headings for these are x and y, are these supposed to xx and yy to match the detailed result orientation or are these relative to global x and y?
3. There appears to be an interface bug where after choosing the "with description" option the description positions will automatically choose indicated graphically anytime I pick any option and click apply then click back in the model window, this is rather annoying. (this setting keeps changing on it's own with no interaction from the user)
4. on the principal tab the online documentation indicates selecting "angle" will add a column to choose the angle to report results against, no such column is added?
