Move a node along a line
is there anyone can tell me how to move a node along a line , the line is not vertical and horizontal.
Simau
Hi @Anonymous
You want to move or to copy ?
Could you attach another picture showing the entire crossing members
M. Agayr
Simau
In this example node 4 will be moved 1.5m
M. Agayr
Stephane.kapetanovic
hi @Anonymous
it is possible to create a plane by 3 points, the x along to the bar, and to move the node according to the local coordinates
best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
StefanoPasquini6790
Hi @Anonymous ,
Both solution are good tricks to solve your issue, the one posted by @Stephane.kapetanovic is quicker and the one posted by @Simau give you the opportunity to use the new reference point for other moves....
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Rafacascudo
I just use the divide tool(checking it to not divide the bar), to create a node in the position I want.
Then, if needed , just move the original node to this new position
Rafael Medeiros
