See attached pdf sheet, if you have a wall panel which is not in the global x or y direction on plan and is skewed diagonally say xy direction. When taking a panel cut through the panel between 2 points, parallel to axis, do you select the x or y direction from the drop down menu as either of them would not be correct as far as I am aware? and if you do select x or y are the reduced results at this location correct or does it have an effect on the reduced forces and moments?
Simon.
