Panel Cut Bug
Panel Cut Bug
Panel Cut Bug
I am trying to take panel cuts through a slab but something is going wrong: instead of having a normal distribution along a line, I am seeing non-sense lines everywhere - please see screenshot and advise if you have had a similar problem.
Many Thanks .
Rafacascudo
can you send the model?
Rafael Medeiros
me1205377
i think you defined the plane of cut to be  parallel to the panel  plane so you didn't really cut through the slab , i believe this is what you did
moustafa elgaar
spot on. silly mistake.
me1205377
Worth mentioning it is a good choice to isolate your panel in a new view to do panel cut. Cause if there is more than one panel in the direction of cut they will be included in the cut
moustafa elgaar
Yeah I know that's happened to me before.
