Pad foundation on ground
JPNR87
JPNR87
calculating small pad foundation laying almost on ground (embedment in ground ca 50 mm determined in probgam) gives error that there is no connection between the foundation and ground.
is'it possible to calculate such kind of foundation in robot?
Thanks!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @JPNR87
It seems that you imposed its size and then its weight is smaller than the uplift force.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
JPNR87
Right, FX were to large and therefore no contact area with ground
