P-Delta not converging
tom.krok
tom.krok
I am trying to design the top chords of bridge trusses using initial imperfection as a bow (robot feature - geometrical imperfection) and running a P-Delta analysis but it cannot converge. What is wrong?
Also, I would imagine the larg deformation would be needed.
Please advise.
the file is there https://inertiaconsulting-my.sharepoint.com/personal/tom_krok_inertiaconsulting_co_uk/_layouts/15/gu...
mustafahesenow
Hi @tom.krok
Sorry for late reply . I had checked this model .In order to check the problem  I deactivate the nonlinear analysis of case no 1312 then I run simple static analysis to check if there is problems .
1- I found out that there is 2 panels assigned as cladding No 95 and 96 are not attached to the structure and every time I delete them they come back .
I made repair mode not working . Then I open new file and I copy your structure to it without this panels but still the same .
See attached picture :
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
tom.krok
Thanks Mustafa,
Sometimes I create another model where the deck, a steel plate, is modelled as a cladding (floor can only be in true horizontal plane) to avoid using FEM shell. This is because the deck/shell is much weaker than the main structure and when performing the buckling analysis, deck buckles first for a vast amount of modes. So, having a deck as a cladding gives me the possibility to do the buckling analysis of the main structure and find the buckling mode relevant to top chords.
Best regards.
Tom
mustafahesenow
Hi Tom ,
I already solve this issue related to panels .
I did one thing as you mentioned for the steel plate i had made it as cladding and I run linear static calculation .
There is instability on Uy direction which is almost 304 mm which is very large displacement and for sure if you go to P-delta will give non convergence .
Mustafa Hesenow
LinkedIn
tom.krok
Thanks Mustafa,
It seems you have a higher version of Robot than mine 2017. I tried to find the install for 2018 and could not find it on Autodesk web page, where it is?
Best regards,
Tom
mustafahesenow
Hi @tom.krok
Here it is
https://www.autodesk.com/products/robot-structural-analysis/overview
You can also open it in 2017 with repair mode .
Mustafa Hesenow
LinkedIn
