Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
P-Delta effect not considered for dilatation load case
5 REPLIES 5
aa_aus
231 Views, 5 Replies
I am applying loads due to special load as dilatation in robot. I have two issues. the software some not able to account for P-delta second order effects. The self-wight cause bending and deflection that shall increase due to compression force from the actions applied as dilatation.
Also, the steel design, i cannot seem to be able to get the software to calculate the buckling parameter althoughApplied loads.pngBuckling parameters not shown.png I have defined this I think properly.
see attached images.
5 REPLIES 5
CaioSaporito
in reply to: aa_aus
Hi @aa_aus!
You put retraction instead of dilatation  and this cause tension on bar. That's why Robot doesn't consider buckling parameters in calculation.
Best regards,
Caio
aa_aus
in reply to: CaioSaporito
Thanks. The deflection seemsBM for deformed shape.png to work now but the software still not show the extra bending moment due to P-delta for the deformed shape
CaioSaporito
in reply to: aa_aus
In my opinion there is no p-delta effect in this model since there is no displacement in direction Z global  at the end of bars (supports). The addition bending moment (Dilatation force  X dZ) doesn't exist.
Anyway, I don't know if you really activated P-delta, so see this image below.
Best regards,
Caio
CaioSaporito
Another thought:
I think you wanna count with "small p-delta" instead of p-delta.
Maybe this thread can help:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/geometric-non-linear-analysis/td-p/44...
" In the current version of Robot only P-∆ is implemented. The P-δ can be accounted for by defining some nodes along the bars"
aa_aus
Thanks a lot. This is now working. I am using another FEA software and results now matching.
Technology Administrators
