Overlap length of reinforcing bar
andrea_pontiggia
andrea_pontiggia
Where can I find the references that uses robots to calculate the overlap length of reinforcing bar with EC2?
thanks
Andrea
Artur.Kosakowski
Autodesk Support
Autodesk Support
Initially it calculated with formula 8.10 assuming:
alfa1   = 1.0,
alfa2   = 1.0,
alfa3   = 1.0,
alfa4   = 1.0,
alfa5   = 1.0,
alfa6   = 1.0
In formula 8.3 it is assumed that SigmaSd = fyd
After generation of reinforcement the verification of beam capacity is launched and at this stage Robot uses formula 8.4 calculating lb,rqd as from formula 8.3 assuming SigmaSd = Areq/Aprov *fyd so that the final overlapping length can be shorter than originally assumed (the final one is the one you can 'see').
Artur Kosakowski
