Open and read from .str file using Python
Mouhammad_mazzaz
Message 1 of 9
Mouhammad_mazzaz
can someone help me, I am trying to extract some data from the str file using python
the thing is that I am able to read the data and print it but I can not search for the data using the line.startswith
how to deal with .str using python
this is a small example not the full code
with open(SourceFile,"r") as file: # where SourceFile = Structure.str
    for line in file:
        if line.startswith(" NODes \n"😞 # search for a keyword
            printing = True
            continue # go to next line
        elif line.startswith(" ;CON"😞
            printing = False
            break #quit file reading
        if printing:
            print(line, file=PointsFile) # where PointsFile = a txt file to save the extracted points data to it
PointsFile.close()
Accepted solutions (3)
Replies (8)
Message 2 of 9
Stephane.kapetanovic
hi @Mouhammad_mazzaz
I imagine you want to use the *.str files to perform outside non-running reads outside of Robot otherwise you can use the API.
At first glance, yes for reading nodes, for a start and a code used once, why not.
Only the first three letters are enough and they vary depending on the language.
For the startwith function you could replace it with contains + 3 letter code.
To stop, the "CON" code of the contours is not always the one following the nodes but any code can interrupt the previous one including END at the end of the file.
Nodes may also contain variable pitch repeat codes and are not always a contiguous list of coordinates, there may be also line breaks. So, you need to create a file reading pattern depending on the active code used.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/str-reference-manual/td-p/3191542
Best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Message 3 of 9
Mouhammad_mazzaz
Hi @Stephane.kapetanovic
Thanks for the reply, Thats helps me alot.
I was actually asking myself that question does the node ends by the contour line every time
so what do you think the best way to transfer the model from robot to other software such as CSI ETABS
let's say the user does not have a license for RSA, and he reviced the concept model as an rtd and str files
and he need to develop the SD or the DD model (schematic or detailed design ) using other software
then the only way is using a tool reads the elements from the str file
I know it could be a lot information missing but it is still better than starting modeling from zero
and believe me it does specially if you have a huge model
Message 4 of 9
Given the age of this software and the expertise of members of this forum and elsewhere, it's highly likely that this conversion method already exists for many of us, in various forms. Note that you can use VB, C#, or Python, to name just the most common options.
Best regards
Message 5 of 9
Mouhammad_mazzaz
Unfortunate there is no such a tool, I've searched and I found only 1 tool and it is quite expensive.
  So I tried to do something similer using python and C#
  Anyway lets hope one of the experts will reply on this topic
Message 6 of 9
Romanich
Hi @Mouhammad_mazzaz ,
Are you talking about Geometry Gym?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 7 of 9
Mouhammad_mazzaz
Hi Romanich,
No It was a tool I saw it in youtube video, but I think Geometry Gym does not have a tool to convert between robot and etabs direct,
I think the only way it can be done through grasshopper, robot to grasshopper then grasshopper to Etabs.
which can be done through the revit
ROBOT TO REVIT then REVIT TO CSI ETABS
I am trying to find a solution for those does not have a robot or they do not know how to work on robot
and I am struggling here with the options.
I've learned some basic in C# and python and I need to work on a real examples so I can implement my programming skills into my work
I would love to share any thing with me .
Thanks in advance
Message 8 of 9
JacquesGaudin
Have you considered exporting the robot model geometry as a dxf file and import it in other softwares?
I found that parsing text files is like opening a can of worms: the code is usually complex, bug-prone and hard to maintain.
Using the dxf export may save you a few headaches.
If you have a good reason to parse str files yourself, you would need to use `while` loops to loop over the various sections of the str file to extract the relevant information.
Jacques
Message 9 of 9
Mouhammad_mazzaz
DXF will export the geometry only.
