Only reaction for new model (API)
Refaat
Advisor Advisor
Message 1 of 27
Refaat
 Hi sirs
 I have large strucutre model  . Can you help me to get only reaction of structure model  and export to a new model of robot to analysis and design only raft foundation?
Note : When i saved the raft as (Substructure) , I couldnt do any changes such as (elastic coeficient value). because i will lose every thing .
Refaat
Replies (26)
Message 21 of 27
Rafal.Gaweda
Autodesk Support
Autodesk Support
So can i put zero?
Yes you can
Rafal Gaweda
Message 22 of 27
Rafal.Gaweda
Autodesk Support
Autodesk Support
You have created and selected superbars also
Rafal Gaweda
Message 23 of 27
RRufino
Yes in fact i did...
Thanks again Rafal.
Message 24 of 27
Rafal is it possible for you to make a new edition with 2 buttons instead (Read old + write to new)
I would like to have the possibility to edit some of the reactions before loading them into the new model.
Message 25 of 27
fareed12
thank you Smiley Happy
Message 26 of 27
Simau
Hi @Rafal.Gaweda
Sorry to come back to this old thread.
I did try your macro to get reactions in the source model  as forces in the target model, but without succes.
The target model is only the 4 supports, which i'll use to  add them a raft.
A simple structure is attached
M. Agayr
Message 27 of 27
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Simau
Are You sure ?
Rafal Gaweda
