- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to make a release that allows this element to only have pressure.
What am i doing wrong?
Please check:
http://help.autodesk.com/view/RSAPRO/2017/ENU/?guid=GUID-A65C66FB-20DA-4B7C-BFE2-3A7B0CF54F7E
I need to do it by code.
Rafael Medeiros
API, vb.net
Rafael Medeiros
Play along with this code, some parameters probably would need to be adjusted for Your needs, but they should be easy to find now.
RobotApplication r = new RobotApplication();
RobotNonlinearLink nll = r.Project.Structure.Nodes.NonlinearLinks.Create("fun");
if (nll != null)
nll.ModelType = IRobotNonlinearLinkModelType.I_NLMT_FORCE_DISPLACEMENT;
nll.SetCurveType(IRobotNonlinearLinkCurveType.I_NLCT_CUSTOM, IRobotNonlinearLinkSemiAxisType.I_NLSAT_POSITIVE);
IRobotNonlinearLinkParams nllp = nll.GetParams(IRobotNonlinearLinkSemiAxisType.I_NLSAT_POSITIVE);
if (nllp != null)
RobotNonlinearLinkParamsCustom nllpc = nllp as RobotNonlinearLinkParamsCustom;
if (nllpc != null)
RobotNonlinearLinkParamsCustomSegment nllps = nllpc.New();
nllps.OriginPoint = 0;
nllps.Expression = "0";
nllps.Constant = false;
nllpc.Set(1, nllps);
nllps.OriginPoint = 1;
nllps.Expression = "1";
nllpc.Set(2, nllps);
nll.SetParams(nllpc, IRobotNonlinearLinkSemiAxisType.I_NLSAT_POSITIVE);
RobotBarRelease rel = r.Project.Structure.Labels.Create(IRobotLabelType.I_LT_BAR_RELEASE, "testRelease") as RobotBarRelease;
RobotBarReleaseData reldata = rel.Data;
RobotNonlinearLinkMngr nllm = reldata.StartNode.NonlinearModel;
nllm.Set(IRobotDegreeOfFreedom.I_DOF_UX, "fun");
r.Project.Structure.Labels.Store(rel);
