Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Only horizontal reaction from column to beam
2 REPLIES 2
valtsARY3H
285 Views, 2 Replies
Is there a way to columns give off only a horizontal force to beams without them directly supporting them, so the beams moment diagram stays as a simply supported one span beam.
2 REPLIES 2
Romanich
in reply to: valtsARY3H
Hi @valtsARY3H ,
Yes, it is possible using Compatible Nodes for example:
Robot Structural Analysis 2022 Help | Compatible nodes | Autodesk
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
valtsARY3H
in reply to: Romanich
In this case which directions should I block? I tried some variants, but didnt get the results I expected and got instabilites in those nodes.
Maybe a quick example of the structure in my post would be the best solution
