one way solid slab
Hello
I tried many approaches to design the attached file as a one way ( X is the main direction) solid slab ( slab on beams), but didn't find the best one
1-first I modeled the slab as a shell with beams ( with offset) I end up by having Myy much bigger then Mxx and a very big deflection 17cm
2- I modeled the slab as a shell but with reduction of moment of inertia ( to let beams take the most of the moment) I end up bye having non-logic results for moments ( also Myy>Mxx) but with reasonable value of deflection
3- I modeled the slab as a shell with material orthotropy with n2=0.001, I end up by having desired results of moments ( Mxx is the main moment) but with big deflection 14cm
I don't know which approach is correct, I will be attaching file here if anybody can help me
Thank you
