one way slab with offset beams
Message 1 of 18
Hi ,
I am trying to create a one way slab sitting on simply supported beams.
The problem when I offset the beams I get very good results for the slab (momentum and shear) . However, the beams results are wrong. (not AS I EXPECTED)
I tried to release the beams supports (pinned-pinned), but even so I still have momentum much smaller than expected in the mid span.
I read many post about that. (certaintly due to induce forces on the beam because of the offset).
my question is 1- how can I solve this problem in order to design all my structure in one go and not design the slab first with offset than removing the offset and design the beam??
2- how to show this offset in 3D (for presentation), because I mange once to do it, then it disapear (I need to put the mouse on the beam to show the offset)
Thanks in advance
Replies (17)
Message 3 of 18
Thank you Rafal for this quick answer, but I already read those posts which didn't answer my question.
is there any way to offset the beam without imposing any extra loadding on it (Keep the momentum same as before the offset)?
Message 4 of 18
AhmedZA
 try  use Rigid link instead and also in case of unidirectional behavior you can use an orthotropic slab to make the slab truly one way spanning that just for suggestions but i'm not sure it gives you more accurate results
display offset
Message 5 of 18
Rafacascudo
So , you only need the offset to be purely graphical , and the whole structure (slab and beams) having the same results you get without any offsets??
Rafael Medeiros
Message 6 of 18
Thank you ahmedeffect for your answer,
I will try  to implemented and see if the rigid link will do.
Message 7 of 18
No exactly, I want the beam and the slab to work as a whole structure, but with offset the moment on the beams are much smaller than expected.
Message 8 of 18
teixeiranh
Nice answer!
How can one access those courses on Autodesk University?
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
Message 9 of 18
AhmedZA
@teixeiranh wrote:
Nice answer!
here>>>  Autodesk Robot Structural Analysis: Steel and RC Design
Message 10 of 18
teixeiranh
Thank you!
Message 11 of 18
Μηχανικος
From what i can see from the diagrams it seems that when the insertion point of the beam is in the middle then the beam behaves as a simply supported beam and the supports do not resist any moments.
However when the insertion point is moved at the bottom of the beam then the beam behaves more like a fixed beam and the supports can resist moments, therefore decreasing the bending moment in the middle since part of the bending moment is resisted by the supports.
Can someone explain why does this actually happens? is this the purpose of the beam offset?
Message 12 of 18
Romanich
Hi Μηχανικος,
For my opinion beam with offsets starts working as a frame with very rigid small columns (rigid links) with h=offset.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 13 of 18
Hi Romanich
Just for a clarification, How can I add the rigid link? does it need to be between columns and beams or between beams and slab? in either way I wasn't able to abbed any help will be appriciated.
based on my understanding it should be replacing the offset , so it should be between slab and beams.
Message 14 of 18
Artur.Kosakowski
Autodesk Support
Autodesk Support
Going back to your original questions:
Model the beams in the way explained in these topics:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/T-slab/m-p/3185418
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Beam-offsets/m-p/3332921
When you have offsets (e.g. if you decide on the approach from the pointy above that would be in the 2nd model intended for the presentation only) they are displayed when you open the offset dialog and not shown any longer when you close it. If you want to keep them being visible switch their display on in the Display dialog.
Artur Kosakowski
Message 15 of 18
Romanich
rolad77, in addition to Artur's answer - you can use my macro which implements Artur's proposal.
http://forums.autodesk.com/t5/robot-structural-analysis/api-macro-creation-of-quasi-t-amp-l-beams/td...
Roman Zhelezniak
Message 16 of 18
Thanks Artur and Romanich
Just a final question, what is the x in your macro Romanich?
Thanks again
Message 17 of 18
Romanich
x is a multiplier for h
Roman Zhelezniak
Message 18 of 18
Ok thanks . so get Befff (the effective flangth width) then find x based on it.
great.
Do u have any example of using a rigid connection? (video)
thanks
