(API) Macro: Creation of quasi T & L RC beams
Romanich
Mentor Mentor
Message 1 of 31
Romanich
I developed small macro with custom functions which will help to create quasi T & L r.c. beams in accordance with the Artur's proposal mentioned in threads:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/T-slab/m-p/3185418
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Beam-offsets/m-p/3332921
Just input data in green cells and select the desired type of section to generate it in Robot. A section will be created with the special name. For example:
@Romanich Artur Kosakowski edited the topic for better findability
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Replies (30)
Message 2 of 31
Rafal.Gaweda
Autodesk Support
Autodesk Support
Nice 🙂
Added to our list
Rafal Gaweda
Message 3 of 31
StefanoPasquini6790
Hi Roman,
As usual "TOP CLASS" member.
Thanks a lot for your API.
Smiley Wink
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 4 of 31
Romanich
Macro was significantly modified in accordance with ACI 318-14 p.8.4.1.8
Roman Zhelezniak
Message 5 of 31
StefanoPasquini6790
PasProStudio
Message 6 of 31
Grohl
"Stole" Romanich's work and added some support for EC2. Hope that's OK, Romanich?
Message 7 of 31
Romanich
Great, thanks Grohl!
Roman Zhelezniak
Message 8 of 31
Μηχανικος
Sounds great,  but how can someone actually use it?
Can someone please describe a step by step procedure? and at which stage of the design someone can use it?
Message 9 of 31
Grohl
Is it something like this you want:
1. Decide what code to use, EC og ACI - ACI seem to have less parameter input than EC.
2. Input necassary parameters to find the L/T beam ratio.
3. Export your section to Robot from Excel
4. Create a slab in RSAP (Dimensions should have been thaught about when creating your section in Excel from point 2)
5. Create beams, with the section you created in Excel, in your slab.
6. Apply boundary conditions
7. Calculate
Message 10 of 31
ledinhchinh0409
hi. Romanich. I do not understand the value of x? Why are 2, 3, 4. I'm just a beginner. Thank you!
Message 11 of 31
Romanich
Hi @ledinhchinh0409, please use v.01
Roman Zhelezniak
Message 12 of 31
mustafahesenow
Hi @Romanich
As always number one!
Many thanks.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 13 of 31
ledinhchinh0409
Is it in Romanic 'spider Pro for Robot'? I am Vietnamese. Have you worked in Vietnam?
Message 14 of 31
Romanich
Xin chào @ledinhchinh0409
Yes and yes. I have been working in Vietnam approximately 1 year, in HCM. If you have an open position, just drop me a line. My bags are already packed.
Roman Zhelezniak
Message 15 of 31
THANK YOU I AM
Beginner IF YOU HAVE VIDEO TO DO THIS TWO WAY RIBBED SLAB
THANK YOU
Message 16 of 31
 THANK YOU any body have video for this file am not successful for do it  if any body have
Message 17 of 31
ledinhchinh0409
Dear @Romanich
Can we improve to automatically determine the T-L beam after the floor has been drawn?
Message 18 of 31
Grohl
You know what type it is based on where you want it in your slab. On the the boundary it will be a L and somewhere in the slab it will be a T.
Message 19 of 31
ledinhchinh0409
Hi. @grohl
Thanks for the quick reply.
I'm solving the problem with manually but when the concrete beam is thought intersection i can use the api to automatically.
Message 20 of 31
Thank you very much for sharing the API.
Can someone also share the API for Rectangular beams please?
