One way distribution of a deck slab on 4 beams
mathias_peron
mathias_peron
Hi everybody,
I'm having a little experience with robot and i don't understand the result. Someone can maybe help me?
Here is what I'm doing:
- I'm drawing a simple structure 4 RC columns / 4 RC beams (5m spans) / 1 Deck slab and only applying the self weight.
- I'm releasing the nodes of my beams to make them independant and draw the bending moment without the slab for the moment. I obtain my p.l²/8 value for each beam.
For the moment everything seems ok.
The problem comes after this step:
- I draw now my Deck slab (One way distributed). Surprise! The bending moments on my beams where the slab doesn't lay on is reduced about half of what it was...
Someone can explain me what happened?
Thank you,
Mathias.
mathias_peron
But if i'm doing with a cladding, the distrution of loads if respected.
Rafacascudo
can you send the model?
Rafael Medeiros
napooil
mathias_peron
Waouh' Napooil, you were right it's working!
But what means "no finite elements" for the elastic stiffness? Which solution is the most representative of the reality? And which one do I have to use everyday when i'm working on concrete structures?
Have a nice day,
Mathias.
Rafacascudo
these are the default "curtain wall" type settings which make a panel work like a regular cladding.
Rafael Medeiros
mathias_peron
Ok thank you very much I understand.
But which setting do I have to use in my everyday work on deck roofs? This one?
