Object Inspector
Object Inspector
andrew_cross2
Message 1 of 11
Object Inspector
andrew_cross2
I am using Autodesk Robot and the object inspector has gone missing from my model. I still have it in older versions of the model and I have tried pressing the display inspector dialogue box but it has not made it appear. See attached.
Andrew
Replies (10)
Message 2 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
clear windows %temp% folder
clear robot cfgusr folder
then start robot and check the file
or
open file in repair mode
Rafal Gaweda
Message 3 of 11
andrew_cross2
Thank you for your reply.
I have cleared the windows temp folder but I cannot find the cfgusr folder. I can find the Cfg folder within the Robot program file but it contains numerous files that would appear should not be cleared; could you please clarify?
Andrew
Message 5 of 11
andrew_cross2
I don't seem to have that folder; I done a search for "cfgusr" in the entire Robot program file and got nothing. I am running Robot Millennium if that has any impact?
Message 6 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
version number of Robot Millennium please.
Appdata folder is a hidden folder; unhide it or type path
Rafal Gaweda
Message 7 of 11
andrew_cross2
Its 21.0.0.2810
I found the hidden folder and removed the files but it has made no difference.
How do i open the file in repair mode?
Message 8 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 9 of 11
andrew_cross2
I have emptied the temp and cfgusr folders and started the file in repair mode but it still has not restored the object inspector. Any other ideas?
Message 10 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Try also: Tools \ Customize \ Open Layouts from Template
Rafal Gaweda
Message 11 of 11
andrew_cross2
That sorted it, thanks for your help!
