I am trying to create a bent joint between two pipes.
I have modelled the vertical pipe as well as the curved joint element and it appears ok.
When I try to used object combination (double Boolean, mixed, external/external) something doesn't work as I was expecting it to work, and I end up with missing portions of the pipe (you can notice it on the left side above the joint).
Please refer to the attached screenshots before/after the object combination.
Can anyone help please?
