I would like to do panel-cuts and see the diagram, but after I clicked "apply" command I didn't see the diagram but only weird lines between nodes. What should I do to see the right panel-cut or what am I doing wrong? Please help.
I attach screenshots before and after.
Solved by Krzysztof_Wasik. Go to Solution.
Hi @Anonymous
Could you share file with cut definition saved for verification
Hi @Anonymous
Points which define cut plane are defined in horizontal plane.
Change z coordinate for at least one of defined points.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
