Hi all,
I tried modeling the simple example on this link:
https://www.youtube.com/watch?v=zww9DjuYpss&t=774s
FYI, the data are given at 1:58.
Please find the attached rtd file.
Per the Youtube video, w2=-4.529mm, my model displays 2.2mm. Am I doing something wrong?
Solved by Krzysztof_Wasik. Go to Solution.
what a reply! The reply is null, nothing there. Can you restate your reply again?
As far as I could understand workflow presented in video.
Displacement w2=-4.529mm is for step 2 with applied total load 2*dP=2*7N=14 N. Robot gives w2=-4.71 mm
You have defined load 7 N which corresponds to displacement w1=2.09 from video (11:55). Robot gives w1=-2.2 mm
