Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Non-linear material model
2 REPLIES 2
Ludwigswe
526 Views, 2 Replies
Hello!
Is it possible to wright a program API that update the stiffnesmatrix due to stress-strain relationship for a material (Data from exprimental test)?
The idea is too make several iteration and for each iteration the stiffnes matrix is uppdated for nodes that exceeds a stress limit.
The analys proess is non-linear but each iteration is carried out as static.
This is just some ideas that i have to be abel to carrie out analysis for fiber reinforced concrete.
Regards
Ludwig
2 REPLIES 2
Rafal.Gaweda
in reply to: Ludwigswe
No
Rafal Gaweda
in reply to: Rafal.Gaweda
Rafal,
If it is possible to modify stiffness parameters, you could, theoretically, do an incremental analysis using the api to run sucessive increments. Of course, not onthe same model but rather regenerating the model and applying the load residual.
Been thinking about this for a while...
