Non-linear analysis no convergence
I am trying to do a non-linear analysis of a structure such as the one in the attached image. There are bar elements attached to shell elements by rigid links.
When performing the analysis, no convergence is reached. I have only changed the section to elasto-plastic of those bar elements which utilization ratios from the elastic analysis were over 1.
I have set a small load increment, increased tolerances for residual loads, and increased the number of iterations to 100 but nothing seems to work.
I am not sure if this is due to very high loads or due to a modelling problem. I would be very grateful if you could give me some tips.
Kind regards,
Ana
paul.bassLH
You can try again with this box and tell us if it is better ??
regards
https://forums.autodesk.com/t5/robot-structural-analysis-forum/non-linear-analysis-involving-model-w...
See if this discussion of artur can help. Otherwise, check first the strength of your members.
