Non-Linear Analysis convergence
suxho95
Message 1 of 8
suxho95
Hello everyone,
I am a new user of Robot analysis, and I am designing a steel building with robot, but unfortunately, I cannot figure it out why i keep getting the error message for non-convergence in the analysis. If anyone can give me guidance because it keeps failing i would deeply appreciate it.
Thanks in advance!
Replies (7)
Message 2 of 8
Rafacascudo
If this does not work , zip and attach your model
Rafael Medeiros
Message 3 of 8
suxho95
Hi Rafael,
Thanks for the feedback. I tried to change the parameters that you mentioned, but the system still keeps failing due to no convergence of system. Attached is the screenshot of the model.
Thanks!
Message 4 of 8
Simau
Hi @suxho95
Hard to say with only screeshots.
Zip and share your model
M. Agayr
Message 5 of 8
suxho95
Hi M.Agayr ,
Attache you may find the robot files for my project.
Thanks in advance for your help.
Message 6 of 8
suxho95
Attached you may the project.
Thanks!
Message 7 of 8
DennisVDijk
Hello @suxho95,
I looked at your model:
[1] all your supports were released horizontally, X and Y direction;
if you want pinned support UX, UY and UZ box must be ticked, full restraint all boxes must be ticked etc. etc.
[2] all you concrete slabs are "slab - rigid diaphragm" if you want the in-plane stiffness of the slabs just use shell.
For a good mesh u should first take the thickness of the slab as a mesh size:
I think 1ft is about 12 inch (im not sure, i use metric)
[3] all you load cases and combinations are on auxillary, you get no results
wind and seismic on auxillary
[4] I'm not sure why you use DAM, i turned it of and your model runs.
I hope this will help you.
Model attached:
Kind regards,
Dennis van Dijk
Structural engineer
www.ibureaunoordwolde.nl
Message 8 of 8
Simau
Hi @suxho95
In your model I corrected a geometric discripancy,
I set the diagonals as truss without releases.
I deleted the releases in the beams in Y direction so that they work as portals with the columns.
I set supports as "pinned".
The main model works fine but with huge displacements
Before you resume DAM, you have to correct your huge loads
Same for LL rain snow
M. Agayr
