I am modeling a foundation slab with different thicknesses for equipment support. The thickness changes are modeled by means of rigid links. The calculation does not converge for the self-weight hypothesis. Could you help me with this?
Solved by Simau. Go to Solution.
Could you share your model
Zip it before attaching
M. Agayr
Removing the rigids LINKS and putting all the panels on the same level will not change the results.
The model converges after this modification.
I also changed some parameters of the nonlinear analysis:
Simple cases 2 3 4 as auxiliary
Marix update after each operation checked
Tolerance at 0.0005 instead of 0.002
Model attached
M. Agayr
