Nodal supports during meshing
saclovitzky
Message 1 of 17
saclovitzky
I'm just wondering why the  created nodal support in a slab/panel was not included during meshing?
Is there any reason for this?
Replies (16)
Message 2 of 17
Romanich
Hi @saclovitzky,
Are you sure that nodes lie in the same plane?
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 17
saclovitzky
yes
Message 4 of 17
Rafacascudo
can you send the model?
Rafael Medeiros
Message 5 of 17
saclovitzky
@rafascudo, pls see attached screenshot and file.
Message 6 of 17
Rafacascudo
Just opened it in repair mode and meshed it again and it worked. File attached
Rafael Medeiros
Message 7 of 17
saclovitzky
@rafascudo, why do you open it in repair mode?it means that the file is corrupted? thx anyway
Message 8 of 17
saclovitzky
@rafascudo, is it necessary that when you have a point load, it shld be included in meshing?
Message 9 of 17
saclovitzky
I have a test model of  3x3m slab and putting  6 point loads(Pls. see attached), when I am meshing it, it is not included. It is really a disaster!
To my horror, when the point loads are not included in the meshing you lose more than 50% of the results value!
I created nodes directly on the slab and why it is still happening ,is this a bug? this is a SERIOUS ERROR!
Message 10 of 17
Rafacascudo
No problems here RSA 2018 with latest patch HF2. See below.
And again , opening your file in repair mode ,makes it work normally. I don´t know what is happenning . Maybe official support can help better
Rafael Medeiros
Message 11 of 17
saclovitzky
@rafascudo
I uploaded the way a created the test model using "autodesk screencast" the title is "node meshing" but I do not where it is uploaded?can you track it?
On the video, it is really shows that nodal loads were not included in the meshing. Pls. see attached.
Message 12 of 17
saclovitzky
@rafascudo
Pls. find below the link for my screencast
https://knowledge.autodesk.com/support/robot-structural-analysis-products/learn-explore/caas/screenc...
Message 13 of 17
saclovitzky
@rafascudo, I also do the same on what you've shown on your screencast but still it doesnt work
what is your comment Artur/Technical Staff?
Message 14 of 17
saclovitzky
This is quite disturbing if you have a large scale model with multiple point loads, this is very easy to overlooked!
Message 15 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @saclovitzky
I think if you actually checked the value of reactions you'd sleep better. All that happened is exactly what you 'asked' for deciding on the use of kinematic constrains rather than mesh adoption to defined nodes Smiley Happy
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 16 of 17
ramon
Thanks Artur.
The only reason why I chose either "Use of kinematic constraints/Obtain coherent FE mesh", is when I encounter "incoherent mesh on edges" error message.
There are times that one or the other is working for a specific model in terms of meshing. As an ordinary user, I would like to suggest that whatever option you choose, point loads/supports will be automatically included in meshing.
Message 17 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @ramon
As you can see on the picture I [posted they actually were by means of the generated kinematic constrains (the point loads were applied to the model).
Artur Kosakowski
