No option for Moving Loads for Building and Plate model types
Message 1 of 8
A quick query, I am looking to use Robot to check a stypical slab for moving mobile crane loads, and i though running a few lines of crane movement across typical spans will do the trick, however, I can not seem to find the option for moving loads. I know that it is suppose to be in Loads=> special loads => moving loads, but as you can see from the attachment, it is not there... any ideas?
@Anonymous Artur Kosakowski edited the topic for better findability
Replies (7)
Message 2 of 8
MUHANNAD.ABU_ABDO
There's no option of moving load in building model !
Muhannad M.Abu Abdo
Structural Design Engineer
Message 3 of 8
Im sorry, can you please clarify? Do you mean I should goto the "Loads" lay out tab? I have tried that, and the option is still unavailable.
Message 4 of 8
MUHANNAD.ABU_ABDO
No .. you must try with frame 3d or shell design .. there's option for moving load in this choice
Muhannad M.Abu Abdo
Message 5 of 8
MUHANNAD.ABU_ABDO
That's what i mean ... in the frame 3d there's option for moving load
Muhannad M.Abu Abdo
Message 6 of 8
Rafacascudo
Tools/customize/customize menu/Loads/Special loads and click on moving to turn it into green
Rafael Medeiros
Message 7 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
or you can change the model to a shell (Geometry > Structure Type).
Artur Kosakowski
Message 8 of 8
This was certainly helpful. CHeers
