Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
No convergence of nonlinear problem
4 REPLIES 4
proyectos7L7LJZ
337 Views, 4 Replies
Good afternoon, I hope someone can help me. My model doesn't converge and I can't find the problem. At the moment I am only interested in the load case 1 to 3 to do a pre-sizing. The floor system that I seek to model is "losacero". Thank you.
https://www.dropbox.com/s/4a1y1sxysnnwgrr/2.1.355%20PAREDES%202%20-%20BODEGA%20Y%20OFICINAS%205.rtd?...
4 REPLIES 4
hi @proyectos7L7LJZ
your braces are declared as lattice bars and you have segmented them at each intersection, purlin or cladding stringer. this causes instabilities which increases the risks of non-convergence.
Best regards
Thanks, I have corrected my braces but the problem still exists. Do you have another idea of whats happening?
https://www.dropbox.com/s/wd7lzy6wqft6xsn/2.1.355%20PAREDES%202%20-%20BODEGA%20Y%20OFICINAS%205.rtd?...
hi @proyectos7L7LJZ
read my remarks on private message
Simau
in reply to: proyectos7L7LJZ
@proyectos7L7LJZ
You have too many releases in your srtucture.
I'll first test the model in linear configuration:
- No release, no PDelta, no "tension only"
- Add releases by step and test the model at each step
If the linear model is ok, Add tension only and test the model
M. Agayr
Technology Administrators
