No convergence of nonlinear problem (temperature load case)
2 REPLIES 2
498 Views, 2 Replies
I modeled a steel structure on Robot which ran fine with no errors and I had all load cases assigned to it (temperature included). However when I increased the section size of a few members due to them being unsafe, I kept getting the "no convergence of nonlinear problem" error.
This error is only in the temperature load case.
I have adjusted the nonlinear analysis parameters, but to no avail. All other load cases (including wind) work fine.
Any help would be really appreciated.
2 REPLIES 2
Artur.Kosakowski
Hi @Anonymous
Assuming that the combinations with this load converges you may just ignore it as it never acts alone.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
in reply to: Artur.Kosakowski
Thanks @Artur.Kosakowski
Technology Administrators
