Hi All,
Certain load combinations gives this error even though the mesh and deformation looks ok, forces look ok.
i believe this error is caused by the inclined / sloping panels. has anyone encounter this issue before and how can i resolve it. don't think this is a buckling or high deformation issue as the movement is only ~15mm.
i have adjusted the following in Robot structural 2017
1. Increase number of iteration for one increment from 40 to e.g. 100
i have attached the robot file for debugging.
Solved by Krzysztof_Wasik. Go to Solution.
Hi @Anonymous
It seems that due to high values of KX KY and KZ and expected uplift effect model is very sensitive to FE mesh size
I have refined FE mesh decreasing mesh size to 0.3
Now all load cases can be calculated
See attached file
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
