No Convergence of non-linear problem
Message 1 of 8
I have this 2D model which I doing an analysis for.
When running my analysis (combination 1) I am getting a warning/error "no convergence of nonlinear problem" . I am not aware of why this is so I do not really know what is going on.
Your help will be appreciated
Your help will be appreciated.
Replies (7)
Message 2 of 8
Simau
@Anonymous
No model attached.
Zip it before upload
M. Agayr
Message 3 of 8
thankyou! here is the attachment.
Message 4 of 8
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Activate large displacements for all load cases.
Krzysztof Wasik
Message 5 of 8
Thank you!
When trying to run the live loads on the short span I am getting the same error, I have imputed the P-Delta and Large Displacements as well. Do you know what the issue could be?
Message 6 of 8
Also when I try and run the analyse on the Live Load Short span, the dead loads remains there. I have tried deleting it and adding it again but the dead load consistently stays every time I change to the live load. Why is this happening?
Message 7 of 8
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
First lad case is always assembly case for cable structure. All other loads are applied on assembly case (generating initial prestressed cable structure stage (assembly stage) . You cannot remove load case 1 when next cases are calculated.
Krzysztof Wasik
Message 8 of 8
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
I think you should define some initial forces in cables. For instance when I will define cables relative elongation dL=-0.003 model converges
Krzysztof Wasik
