- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I have a small issue with one of my models. I have a slab on soil with uplift with 2 walls resting on it.
I predefined my soil elasticity kz (100MPa/m) which i put as (100000 kN/m3) in the slab thickness wizard.
Now i need to fixed my horizontal d.o.fs, so i used a planar support with fixed Ux and Uy.
When I run my analysis i get errors about convergence. I have already made the changes I've seen on several posts, that is changing the analysis parameters with matrix updating after each iteration and so on. But no luck at all.
However, if I change my support to an elastic support with a kZ of 100000 kN/m and fixed Ux and Uy, the analysis runs smoothly. But this is not what I need, if I do that, it is as if I am overestimating my kZ or 'doubling' it since I have already specified foundation elasticity parameters in my base slab thickness. (correct me if I'm wrong).
Your advice and comments will be highly appreciated. I am also attaching my model. Thanks
RSAP 2017 - Windows 10
