Hi Guys
I am currently modelling an existing bridge to AS5100. The bridge is 8 lanes wide and approximately 70m long.
I have set up a moving load in each lane for 3 different vehicle types (total of 24 moving cases). The step increment for each moving load is 0.5m. I have not added any case combinations to the model yet.
I expected the model would take some time to crunch the numbers, but model takes 30-60min to run just to generate the moving load forces, and then the model has become frustratingly slow to edit with long delays between each click. My questions are:
1. Is the slow model due to the computational effort required, or are there modelling issues that are causing it to slow down (file attached)?
2. What is the best way to approach this analysis? I have read a previous post which suggests generating moving loads in RSA, then exporting to excel for combinations. I'm happy to do this, but I am having trouble just generating the results from primary in the first place.
3. Are there any settings/Job preferences that can be adjusted to help speed things up?
Any help or other ideas would be appreciated.
Aaron
