Moving load
Moving load
Nissar19
Moving load
Nissar19
Hi!
I wonder at RSA calculate Self-weight  of Vehicle loads?
Accepted solutions (4)
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Nissar19
I'm not sure if I understand you correctly but if you define a model of a vehicle RSA will calculate its weight Smiley Happy
Artur Kosakowski
mustafahesenow
The weight of Vehicle is already considered in the data base + the carrying load
So the weight mentioned in Data base is the operation weight (vehicle weight + maximum Carrying loads )
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @mustafahesenow
Thank you. I'll start with the coffee next time Smiley Happy
Artur Kosakowski
Nissar19
Thanks a lot Mustafa Hesenow.
