Moving load in a circular pattern
Message 1 of 47
Today my question is how do I get the concentrated forces, I define in the moving loads, to point in the same place for example a center of circle?
In the picture I attached the FX force is pointing to the wrong direction.
Replies (46)
Message 2 of 47
Artur.Kosakowski
Autodesk Support
Autodesk Support
The force will always be perpendicular to the route therefore you need to have large number of straight segments for the polyline.
Artur Kosakowski
Message 3 of 47
I am designing a solid concrete cylinder which has moving loads at the top and its surface area. I was thinking of modeling it as a solid and using object type: shell. Problem is I can't apply moving loads to the cylinder object. Can someone tell me if there is a smarter way of doing this or how can I get the moving loads working?
Message 4 of 47
Rafal.Gaweda
Autodesk Support
Autodesk Support
I do not understand.
See example video:
Rafal Gaweda
Message 5 of 47
If you take a look at the picture perhaps you can then understand what I was trying to say. I can get the moving load working in a pipe sort of structure, like that video has, no problem.
Message 6 of 47
Rafal.Gaweda
Autodesk Support
Autodesk Support
DO not use ACIS objects.
Use standard ones
Rafal Gaweda
Message 7 of 47
Why does the program have them if one should not use them?
Message 8 of 47
I just realized that the suggested solution works when the concetrated loads are the same but is there a way to make the same thing happen with different loads?
Message 9 of 47
Rafal.Gaweda
Autodesk Support
Autodesk Support
Please explain
Rafal Gaweda
Message 10 of 47
One load facing towards the center is 100 kN and the other is 200 kN which is also facing towards the center for example.
Message 11 of 47
Rafal.Gaweda
Autodesk Support
Autodesk Support
Artur's example used as a base:
Rafal Gaweda
Message 12 of 47
Sorry, I should've been more clear. I don't mean projections. A case where, there is another load for example 5 meters apart from the other.
Message 13 of 47
Rafal.Gaweda
Autodesk Support
Autodesk Support
Vehicle is always considered as straight.
So create manually number of simple cases with correct loads
Rafal Gaweda
Message 14 of 47
Alright, thank you.
I've got to ask you because this is really bothering me, how would you model a solid concrete cylinder?
We want to see moment results and we also want the self-weight of the cylinder to be correct. Also preferably structures that are connected to the cylinder are shell structures.
Message 15 of 47
Rafacascudo
Maybe you can try to vary the load using the route parameters.For each route(polyline) edge you can assign a load multiplier for each wheel on all 3 directions. It only works for symetrical vehicles
Rafael Medeiros
Message 16 of 47
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 17 of 47
What I mean by solid is that the cross-section is not hollow inside. If you could give and idea, how to model something like that would be great.
Message 18 of 47
Rafal.Gaweda
Autodesk Support
Autodesk Support
I am afraid I do not understand.
Any sketch, drawing please.
Rafal Gaweda
Message 19 of 47
Thank you for you suggestion but the problem is that the concentrated loads would change according to their place. They are supposed to remain the same no matter where they are for example in a case where the loads need to be in an exact order, so I guess the best resolution is the one Rafal gave.
Message 20 of 47
Maybe this image will help. Basicly like a column but so huge that it's best not to model it as a bar and because there are moving loads on it from different directions.
