Modelling Tunnel Ring Using Shell Elements
STAATH64T
STAATH64T
Hi community,
I am trying to create a 1 m wide shell element to simulate a tunnel ring.
I have assigned compression-only soil–structure interaction springs using the Foundation Elasticity parameters.
I have the following questions:
  1. How do you account for the radial rotation of the ring in the model? Do you assign rotational springs about the y-axis, i.e. along the longitudinal axis of the tunnel? If so, how is this typically implemented?
  2. How do you model the joint connections between the individual segments?
I have attached my model for reference.
Thank you in advance for your time and help.
Best regards,
Stavros
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @STAATH64T
To block rotation and displacement along segment length it is enough to define small nonzero Kx and Ky values in Parameters of foundation elasticity
Krzysztof Wasik
lauri_barnhart
Welcome to the community, @STAATH64T.
Hope you are well. Following up to see if the information provided by Krzysztof_Wasik clarified your question. If it did, please consider clicking on the 'Accept Solution' button.
Lauri | Community Manager
