Modelisation Problem
You can see a picture of my modelisation.
I make a pipe in the middle and the others are cables.
But the problem with the cables is the instability
I want to know how i can resolve it
I try to put releases but the problem persits
What i need to do ?
Merci
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi
Fixed supports in nodes 1 2 9 10.
If it does not help please attach robot file to post
Rafal Gaweda
Good luck 😉
Rafal.Gaweda
Autodesk Support
Autodesk Support
@Anonymous wrote:
Good luck 😉
Not luck needed  - knowledge and experience only 🙂
From
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-C718E208-2359-49A0-9C8E-FAB4EA49694-242.htm
"Limitations:
  • For cable elements, a release definition is impossible, because bending and torsional rigidity do not apply to such elements."
-> bar 5 is unstable - it can rotate around X - either it can be neglected or RX support should be applied to eg node 8
PDelta analysis + Newton-Raphson method should be run
Corected model attached
Rafal Gaweda
