Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Modeling complex walls
Message 1 of 8
I want to model a "sandwich" wall which has two outer layers of thin reinforced concrete and a core layer of masonry.  How can be done? the overall thickness of the wall is  6cm rc concrete (layer1)+ 50cm masonry (layer 2) +  6cm rc concrete (layer1), overall thickness 82cm. Should I go for volumetric structure instead of planar finite elements?
Kostas Bourmpakis
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
I can think of 3 options:
1. Use a solid model
2. Use a shell model with 3 panels connected with rigid links
3. Use a shell model with a user defined orthotropic thickness
Artur Kosakowski
Message 3 of 8
Thank you Mr. Kosakowski for your answer.
It is difficult for me to understand the procedure for the following option:
I dont see any option in the user defined for modelling 3 layers as composite.
Additional help please?
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Indeed such definition is not available directly but you may try to use this one instead:
Artur Kosakowski
Message 5 of 8
Sorry (it must be me) but I dont get it.
How I ll find and enter the following values for 3 layers with different material?
·      membrane stiffness matrix D
·      bending stiffness matrix K
·      shear stiffness matrix H
Regarding the second solution of 3 panels connected with rigid links, is it enough with the rigid links on the border lines? does it calculate the material as continuous between the layers/panels? it performs as one element?
Finally what is a solid model. first time I ecounter it
Message 6 of 8
Since i am struggling to cope with this task, could someone be so kind and provide me a brief guidance
or an example (if it exist) regarding the modelling of a 3 layer wall composed from 2 external layers of reinforced concrete
and an internal (core) of masonry. I didn't expect it to be so complicated....
Kostas
Message 7 of 8
Come on.... there should be a champion in this forum to help me!
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
I don't have the exact formulas for the stiffness matrix for such type of sandwich wall. You may try to search the web for something like this:
http://contrails.iit.edu/digitalcollection/1968/AFFDLTR68-150article17.pdf
On the other hand you may also consider the following approach if you find it acceptable:
1. Create a composite profile in the Section Builder of  Robot
2. Calculate its weighted properties
3. Define a new thickness with material and thicknness that matches the EA* value for the calculated section
4. Use the IY reduction to match EIz* value of the caclulated section
Artur Kosakowski
