- Mute
- Permalink
- Report
Hi all,
I'm looking to model CLT panels. I've done some searching internally (corporate) and externally (forums) and I'm finding little support in this task, so I'm hoping to get some good results from this. At the end of this thread, I'm hoping to be able to model CLT panel in Robot, such that loads can be distributed to multiple edge supports.
I understand from internal documents, where colleagues have modeled CLT in other software packages, that there may be a way to homogonize the materials in the two principle directions of the plane of the panel, and then to come up with coefficients (n1 and n2 in Panel>Thickness ... > Othotropic >material orthotropy). I'm not sure if this is this method of modeling the panel thickness will allow for analysis of all the strength and serviceability criteria.
Another possible solution is to do a user-defined material, and to manually define the stiffness matrix. This is a rather complex route, but I'm open to trying to figure it out.
If anyone has experience with either of these methods, or is also interested in figuring it out, let's chat!
Cheers
