Modeling a Curved slab-balcony
saclovitzky
saclovitzky
How do you model a curve slab?
Pls. see attached screenshot.
Any help will be greatly appreciated.
Replies (10)
Rafal.Gaweda
Autodesk Support
Autodesk Support
4 arcs on the edge ?
Rafal Gaweda
Rafacascudo
Import it from architecture drawing??
Rafael Medeiros
napooil
As your picture . I guess you model Curved slab in revit therefore you can send analytical model to robot. as picture
saclovitzky
thanks all guys, I've found a workaround by using "arc" and "polyline" combination.
Hey Saclovitzky, how did you actually model with the arcs and polylines? I have a similar project and I'm finding it difficult to make the curved slabs
Rafacascudo
On polyline dialog there are small icons where you alternate to arc drawing mode
Rafael Medeiros
I was able to make the outline Rafa but I wasn't able to "fill" in the slab sadly.
Rafacascudo
On the same dialog , on parameters ,you should mark it as "panel"
Rafael Medeiros
Oh. Got it! Thank You!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @saclovitzky
Do you mind posting your workaround as a picture (pictures) so that it is easier to both find and follow for those of us who are still looking for the solution? Thank you.
Artur Kosakowski
