Model warnings
Model warnings
Message 1 of 21
Model warnings
Hi
I'm new to robot and I have taken an structure from revit and put it in to Robot - so I can use it for stresses etc. But every time I try and run an analysis of my structure, it gives me warnings and errors:
- Not a BODY Get
- Isolated node/nodes have been found
- Incoherent mesh on edges
- Separate structure
- Instability problems
I have already tried to follow some of the guides/answers in these different forums that concern my problems - but it dosen't seem to work.
Can someone please help? (I have attached my file)
Thanks, Kasper.
Replies (20)
Message 2 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
I am afraid you have to remodel it without ACIS.
If you want to make any design you have to remodel it using panels (\shell finite elements) and bars instead of volumetric elements.
Rafal Gaweda
Message 3 of 21
So it isnt possible to take a model from revit and put into robot? Or should I have done it in a different way?
Message 4 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 5 of 21
Is there any way I can remodel my structure inside Robot?
Message 6 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
Yes, just do it.
BTW: have you sent model from revit? What effect?
Rafal Gaweda
Message 7 of 21
I can't sent it from revit to robot (by revit) because i'm missing the option: "Robot Structual Analisys Link" - I only have "Reinforcement Code Check".
So i'm still using the .sat file - but i'm not sure how to remodel it, because the structure is taken from revit and is not made from robot.
Message 9 of 21
It worked beautifully! I will try and work with this file now - and see if I can worked it out.
Thank you for your help!
Message 10 of 21
I'm trying to sent a new construction from revit to robot - but when i'm trying to do it - a new box arrive afterwards: "Mapping of elements" and it says not all the elements have been assigned. What should I do?
Message 11 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
You have to assign section from Robot database(s) to the section name from Revit -> press "Not Assigned" button in each row ....
Rafal Gaweda
Message 12 of 21
But it is only a standard selection - none of mine are there?
Message 13 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
It seems you have not any of them in Robot.
Rafal Gaweda
Message 14 of 21
What can i do then?
Message 15 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
Create such section in Robot Section Definition (Section Builder) module, save to database or use any standard \ similar ones instead and then assign it correctly while importing model from Revit.
Rafal Gaweda
Message 16 of 21
Okay. If i want to make a structure like in the picture - do I have to do it from scratch or is it possible to download some "help-construction" which I can remodel somewhere?
Message 17 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example:
- save section view from family editor as dxf
- open it is Section Definition module (mind correct units) in Robot
- assign material
- calculate properties
- save section to database
Rafal Gaweda
Message 18 of 21
And where is the "Section Definition module". I can't find it
Message 19 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
Dear Kasper
I think this is a time to start to learn robot
http://forums.autodesk.com/t5/forums/searchpage/tab/message?location=forum-board%3A351&q=tutorial&fi...
and\or use more extensively Search on this forum
http://forums.autodesk.com/t5/robot-structural-analysis/tips-for-using-search-in-the-autodesk-forums...
Rafal Gaweda
Message 20 of 21
When i'm "Saving Section to Database" and it says dimension 1,2 and 3. What dimensions does it mean?
