Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Model not converging: SW Load Case, Compression Springs
3 REPLIES 3
561 Views, 3 Replies
Hi Guys,
As the title suggests my model does not converge when analysing just for self weight when introducing compression only springs on the base slab and or walls. Structure has 2 floors underground.
Note the model runs fine when springs are set to normal (ie tension and compression). The "supports" have been input via the foundation elasticity using the thickness of the panels.
Please see model attached.
Labels (3)
3 REPLIES 3
Krzysztof_Wasik
Hi @Anonymous
Model converges for the following calculation parameters.
I would suggest to define weak horizontal elastic support for foundation panels (simulating friction). It will improve convergence (tolerance can be increased to 0.005)
Krzysztof Wasik
in reply to: Krzysztof_Wasik
Hi Krzysztof,
Thanks for your response and time.
Yup, the model runs now but just for this load case. However as I increase the complexity of load cases/combos I once again run into convergence issues. Good tip on the soil friction, does help, thanks!
Do you have any suggestions as to why my model fundamentally has convergence issues? What things could I do or avoid to help my analysis converge?
Many thanks
Krzysztof_Wasik
Hi @Anonymous
It is usually model/load related. So I cannot say more without specific cases analysis.
I would suggest calculation load combinations only (simple cases analysis in non linear model makes no sense)
I see that model geometry can be improved
Krzysztof Wasik
