Hi
While I have been editing an average size model the size of the RTD file has swollen from 11Mb to 108Mb and ofcourse at the same time become very sluggish and slow.
The file may be seen here
http://www.filemail.com/d/ykthojkccbjvvpa
I do regularily save the file under a new name but this does not reduce the size.
I have done a save as "RTD without results" but that did not reduce the size.
I tried opening in repair mode - which helped only litle because the file only got reduced to 50Mb
Can anyone advise me what the problem is and how i get it down to 11Mb again.
Most of the model is only bars so that should not produce a huge filesize. But I introduced some panels only for load distribution. I am bit suspicious that perhaps som cracy meshing is going on in the background which I am not aware of.
kindly
KLEL
