Model file grown to huge size
Message 1 of 9
Hi
While I have been editing an average size model the size of the RTD file has swollen from 11Mb to 108Mb and ofcourse at the same time become very sluggish and slow.
The file may be seen here
http://www.filemail.com/d/ykthojkccbjvvpa
I do regularily save the file under a new name but this does not reduce the size.
I have done a save as "RTD without results" but that did not reduce the size.
I tried opening in repair mode - which helped only litle because the file only got reduced to 50Mb
Can anyone advise me what the problem is and how i get it down to 11Mb again.
Most of the model is only bars so that should not produce a huge filesize. But I introduced some panels only for load distribution. I am bit suspicious that perhaps som cracy meshing is going on in the background which I am not aware of.
kindly
KLEL
Replies (8)
Message 2 of 9
Rafacascudo
Just to be clear, you have to save it without results AND with a new name.
Another thing that takes a lot o space is screenshot
Rafael Medeiros
Message 3 of 9
Thanks for your reply, but as I said in my first email i do regularly save with a new name and also as RTD without results. I just tried again just now and it makes no difference whatsoever. Only went from 115.9 to 114.9Mb. So there must be some other issue.
I have not taken any screenshots nor worked with any results. I am simply modelling in geometrical mode, doing some simple changes to a model and while I do this it grows from 11Mb to 115Mb. I do not understand what goes on and it makes the model very slow and difficult to work with.
Kindly KLEL
Message 4 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Look at Load table.
Hundreds of the same loads.
Rafal Gaweda
Message 5 of 9
Thanks, perhaps this is the problem.
I have not yet been able to delete them because the program stops the responding when the load mode. Physical memory usage grows to 99%.
Is there a way to delete them without going to a mode which freezes the program.
How have these loads been created. I have not even been inside the load mode while editing the model - so these loads are somehow generated automatically by the program.
Message 6 of 9
Okay, now I found that I can open the load table without going to the load mode. So now I have the table and can see the loads.
But to identify which one to delete and how to delete them is not a small task. Perhaps I should just delete all.
Message 7 of 9
I can open the load table and see all the unwanted load components. But as far as I can see I am not alowed to delete rows in the table. I still have to go into this load mode which makes the program freeze supposedly as it tries to load all these loads graphichally
How to i delet the loads.
Must I simple delete all the entire loadcases from the pulldown menu at the top ? It is quite annoying to have to redo all the loads - just because robot corrupted them. What if it happens again?
Message 8 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
What are the actual loads you defined in cases 1, 3 and 4. Are they just self-weight applied to the entire model in the Z, X and Y directions with corresponding factors plus uniform load applied to panels in the same manner?
Have you built your model by coping its part via clipboard?
Artur Kosakowski
Message 9 of 9
Hi
I have attached an earlier version of the model(25) before I started the editing which has corrupted the model so badly.
http://www.filemail.com/d/klrwvpbzdhpajln?utm_source=confirmation&utm_medium=email&utm_campaign=Emai...
Loads are:
- autogenerated selfweigth,
- dead load as panel loads,
- some deadload as point loads,
- live load as panelloads,
- some live load as pointloads
- and then two loadcases for X and Y with accidental loads which takes a certain percentage and adds it as horisontal load.
Yes I used some copy function when I created the gallery in level 6 which I have not yet added a panel to.I copied it from level 6+ and then modified it inplace
Is there some bug in the copy function?
