Model a beam hanged to frame rafter
ahmadmahrous_1
Message 1 of 11
ahmadmahrous_1
I want to model a beam that is supported by columns hanged from frame rafter as shown in attatched pic:
beams 7,8 are supported by  columns 4,5,6 which are hanged from rafter.
Thank You,
Replies (10)
Message 2 of 11
Simau
Hi @ahmadmahrous_1
According to your screenshot you already modeled your structure.
So what is your probleme?
M. Agayr
Message 3 of 11
ahmadmahrous_1
What I am asking about how to model the load transfer scenario from beams 7,8 to 4,5,6 to the rafter
so the  beams 7,8 are continuous beam supported on 3 points and columns 4,5,6 takes reactions of beams as axial force then transfer it to the rafter as concentrated loads.
Message 4 of 11
Simau
Scenarion 1
All your structure (1to8) is poured and supported till concrete setting
Scenarion 2
1 2 3 are poured and after concrete setting you add 4 5 6 7 8.
You may use Phases
M. Agayr
Message 5 of 11
ahmadmahrous_1
Could you please explain?
This is a steel structure all members are steel
Message 6 of 11
Simau
After reflection, for your structure, it is not necessary to use the phases.
So concrete or steel structure, just run your model with all kind of loads you need
M. Agayr
Message 7 of 11
ahmadmahrous_1
Thank you @Simau
I did but then the beams transfer load only to columns 4,6 and not 5 and act as simply supported beam not continuous as no support at column 5. How to tell robot that column 5 is also supporting the beams??
Message 8 of 11
Simau
It depends of stiffness off different members
Please attach your model for analyse
M. Agayr
Message 9 of 11
Simau
if the stiffness of 4 6 is much greater than that of 5, 4 will not transmit any load
M. Agayr
Message 10 of 11
ahmadmahrous_1
All Members are of  the same section
Her is the Model I want results of beam 7,8 to be the same as 9,10 as they have the same load, section and length.
Message 11 of 11
Simau
Something like this
model attached
M. Agayr
