Meshing problem
Meshing problem
Message 1 of 30
Meshing problem
it seems that no matter what I try (various meshng methods, size etc.) I cannot get a proper mesh for the walls of the attached model.
Moreover If I particularly select one of the walls with meshing issues and then delete its mesh, then I get other walls mesh also deleted... very awkard...
I already spent a lot of time trying to figure it out, so I though sharing this issue here would be helpful.
thanks for any input.
I'm using Robot 2013 under windows XP
Replies (29)
Message 21 of 30
Thanks you very much
I don't know how to fix error 1
please help me
I asked for more: How to progaming VBA between Excel and ROBOT
Message 22 of 30
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please
Rafal Gaweda
Message 23 of 30
Thanks you
This is my file, in link below
http://www.mediafire.com/?540c635cs8dhbj9
Message 24 of 30
Rafal.Gaweda
Autodesk Support
Autodesk Support
Movie: http://screencast.com/t/IJPBeBCHDz
Then apply correct material to panels
Rafal Gaweda
Message 25 of 30
Thanks you veryyy much
I am looking for learn Rsap &Revit from you
Can you help me okay?
Thanks you very much again
Message 26 of 30
Rafal.Gaweda
Autodesk Support
Autodesk Support
We are teaching you all the time 🙂
Rafal Gaweda
Message 27 of 30
I have the same problem: I have a model with different size of the mesh(same larger and other smaller): how can I obtain regular mesh' dimensions for all the elements?
When I try to mesh one part all the model take the same mesh.
Is it correct to use these options?:
in TOOLS , JOB PREFERENCES , MESHING: Kinematic constrains
In ANALYSIS, MESHING: Meshing Method, authomatic selection, size (and I insert the size I want)
Probably there is something in my procedure that is incorrect.
I have attached the model here below
Message 28 of 30
Rafacascudo
Select the panel , click on "meshing options" icon and set whatever you want for only this selected panel
Rafael Medeiros
Message 29 of 30
t.sautierr
Never use kinematic contraint Master Rafal would say!
Your mesh has to work without this option.
Size : if you choose automatic and 1,2,3,4 etc ..... it means that the sides of the pannel will be divided by 1,2,3,4 so different size of pannel -> different size of FE. I you want to havemore or less the same size of FE than choose USER definition and set the lenght you want.
Search on the forum, a lot of threads are talking about meshing option.
Message 30 of 30
t.sautierr
Parameters that makes (generally) clean meshes.
