Meshing Issues in Robot
bhawesh_lohaniE3UGF
Message 1 of 11
bhawesh_lohaniE3UGF
I have checked the coordinates of panels in robot and they are matching exactly yet i am getting incoherent meshing in edges. Is there any option in robot to automatically merge nodes of panels. Also while running robot, the model shows isolated nodes everytime even though i delete them.
Accepted solutions (3)
Replies (10)
Message 2 of 11
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @bhawesh_lohaniE3UGF
Please share model for verification
  • Save file as RTD without results
  • Zip saved model
  • Upload it to this forum thread.
Krzysztof Wasik
Message 3 of 11
bhawesh_lohaniE3UGF
Hi, I have attached the model file for your review.
Message 4 of 11
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Model is not defined preciselly. As an example please see connection between objects
152 178 415 516 626 627 647 648
Panels should have common edges and common corners.
Also beams are not defined along panels edges
Example for objects  132 (panel) and  619 620 (beams)
You can try to correct model by
  • Detailed correction before meshing
  • Meshing model step by step by selecting group of panels (as an example by thickness) and meshing selected panels with Analysis >Meshing >Local mesh generation
  • Increaseing model generation tolerance in Analysis >Analysis types >Structure model (before calculation)
Refer to corrected model meshed in version 2025.
Krzysztof Wasik
Message 5 of 11
Stephane.kapetanovic
hi @bhawesh_lohaniE3UGF
Here is a report using a scale from 0 to 10.
I hope you find it helpful.
Best Regards
report deleted
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Message 6 of 11
bhawesh_lohaniE3UGF
Hi, thanks for the solution. I want to know that is there any quick method to correct this modelling issue of Beams and Panel connection. One solution i know of extending the beams and finding the intersection points using beam elements on panel surface. But is there any other quick method?
Message 7 of 11
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Your solution should work but you can also try to use detailed correction of beam endnodes to panel planes
Refer to video
Krzysztof Wasik
Message 8 of 11
bhawesh_lohaniE3UGF
Thanks for the solution. That was very helpful and saved my time. Can you also send a video solution for finding the intersection nodes of planes. Bcz i model structures that have arbitary planes, therefore sometimes the intersection points vary by decimals.
Message 9 of 11
Krzysztof_Wasik
Autodesk Support
Autodesk Support
There is no speciall tool for planes intersection , but you can use Edit >Cut by plane option to find intersection points of panels.
Refer to video
Krzysztof Wasik
Message 10 of 11
bhawesh_lohaniE3UGF
Hi @Krzysztof_Wasik
How can i check the moments in a beam element at face location.
Message 11 of 11
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Open Results >Forces then select required load cases and member.
Program shows results in member/beam endnodes (by default)
Krzysztof Wasik
